Help me backup logs on Samsung Wave S8500
Dear Experts,
I have Samsung Wave S8500. For safe side I want to create backup, but have no idea how to do it. I would appreciate if anybody help me backup logs on Samsung Wave S8500. Please write in detail
Answered By 5 points N/A #151655
You want to create backup for Samsung Wave S8500, I recommended to you can use “Phonecopy” which is use for organize phone data.
Another option, you can use any antivirus, which is always provide to create the backup of your data. You can use Avira and kasperskey mobile software for creating the backup.
You can download the Antivirus from the mentioned link:
http://gallery.mobile9.com/c/samsung-s8500-wave-softwares_2894/1/security_52/
I hope it will helpful. Thanks!
