Help me to change speed of gif Mac
I using MAC for only a year, and I don't know every feature of it but please tell me how can I make a faster or slower GIF?
Creating an animated GIF file is just simple that is if you know how to create your own image or maybe you just want to make a short slide show of a couple of pictures. The transition between the displayed pictures or images is controlled by the time you specified when you created the file. For example you want to create an animated GIF out of 3 images. For the animation or the slide show to happen, you need to indicate or set the specific time or the amount of time before the next picture is displayed.
To test how it is done, you may try it by visiting makeagif | create animated gifs the free and easy way which is an online-animated GIFs creation site.
Notifications
