Help me to Create Backup
Good day and the important thing is that there is a process of creating backing up of data that is available in your computer. It is possible that backing up the data, when the 2 systems are hooked up and then you must configure those in a proper manner. It must meet the minimum requirements of 2GB ram and it must work properly in vista or higher version of windows. You can make use of it to restore the files that are stored in EHD and somewhere I heard that it is possible and hope this will fix your solution.
Thank You.
I think it’s still possible to create a backup after your system crashes. But, that is, if you can find a way on how to boot your machine again, that’s the only time that you can try on creating a backup of your system. But it still doesn’t guarantee that the backup process will work since your system may have other problems as a result of the system crashing.
If you will be able to successfully boot up your computer, you should then check your machine for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostics test on your machine, use disk utility applications like Norton Utilities, PC Tools Performance Toolkit, or Norton SystemWorks. After the full diagnostics on your hard drive, you may now attempt on starting the backup process. Your system must first be free from errors so you can have a 100% error-free backup copy.
Notifications
