Help me to create windows 7 system repair disc
Hi guys ,
I want to create a windows 7 repair disc , so I can repair the system anytime using that disc ,
please would you kindly give me necessary steps to do this?
Hi guys ,
Hi Kiel Sanchez,
To create a system repair disc for your system do the following steps :
If you want to use the repair disc, boot your system, with disc on your drive, and press OK if prompted. Hope this helps!!!!
Creating a system recovery disc is very helpful because it can provide you system recovery options that will allow you to repair Windows in case a serious error happens. In Microsoft Windows 7, creating a system recovery disc is easy. To create your own system recovery disc, click “Start”, “Control Panel”, “System and Maintenance”, and then “Backup and Restore”.
On the left pane, click “Create a system repair disc” then just follow the instructions. Enter your administrator password when you are prompted and continue. The process may also require you to insert the Windows setup CD. When this happens, it means the files required to build the system repair disc cannot be located on your computer.
In this case, simply insert the Windows 7 setup CD on your optical drive and then continue.
