Help me on creating virtual machine
I’m trying to create a virtual machine with Windows server 2008 (64-bit). This error appeared when I’m trying to install VMware tools. I thought that logging in as an administrator would resolve the issue.
This did not help. Can you help on this?
Error: “Error 25030.Setup failed to load kernel driver (vmrawdsk)”
Thanks,
Jacintha
Answered By 0 points N/A #90629
The firs thing is you should have to mention in your question is that which virtual machine work station you are using to provide help of the specific virtual machine and solve your problem because there are many virtual machine work stations.
I will provide the information about the virtual box and VMware.
In virtual box you have to click on the new in the main menu and the click on next to next step and then select the range of Ram How much ram will be used and then select the ISO file and then ok and that's it your virtual machine will work finely.
Hope this will solve your problem.thanks
