Help me with Disk management
I was working with DISK MANAGEMENT system. Unfortunately, I deleted my D and F drive. All my important documents were there. What can I do?
There are different data recovery software on the Internet. You can download this kind of software like “EASEUS Partition Recovery 5.0.1” and use it.
However, you can get 70% of your missing data.
Dear Hassan,
There are many software/ utilities that can be used to recover your lost or deleted partition. But, I personally like active partition recovery software which is free to download from any software website like Windows PC software downloads
It can recover your partition and data. If a partition is not recovered successfully, this software will recover 80% of your data.
Otherwise, if you have a working experience of MS-DOS, then you should use partition recovery bootable CD (DOS Mode Software) for partition recovery, but you should have to handle DOS commands.
Another exciting utility of Partition recovery is Stellar Phoenix Partition Recovery Software Pro Edition. You can download this utility from here
Hope you will overcome your problem soon.
Thanks,
Aamir
There are many software or utility applications that can be used to recover your lost or deleted partition.
But, I personally like Active Partition Recovery which is free to download from any software website like CNET Active@ Partition Recovery.
It can recover your partition and data. If the partition has not been recovered successfully, this software will recover 80% of your data.
Or, if you know how to work in MS-DOS, then you should use partition recovery bootable CD [DOS Mode software] for partition recovery, but you should know how to handle DOS commands.
Another exciting utility on partition recovery is Stellar Phoenix Partition Recovery Professional.
You can download this utility from Stellar™ Data Recovery | Stellar Phoenix Partition Recovery – Professional.
Here’s what Stellar Phoenix Partition Recovery – Professional offers:
