Help me to extract mobile numbers from phone?
I’ve Nokia E71 and was wondering if there is a way to extract mobile numbers from my cell to computer? Any kind of help would be appreciated.
From where will you extract mobile numbers? Is it stored and save as a text file? Or you want to get all the numbers from your phone and save it as a text file on your computer. If it is saved as a text file, use MS Word to extract. Open your Word and then open the text file, go to the Edit option and then hit Find. Click More and then select Using Wildcards. Type in Find What, the first 3 numbers of the phone numbers in your file or the area code. Let's say its 091, type 091*. But if you want to extract all the numbers in your contact list and save it as a text file on your computer, I'm afraid you have to do it manually.
