Help me figure out the most suitable Micro SD card
Hello everybody,
I have purchased Nokia Lumia 1520 recently. It supports micro SD card of volume up to 64GB. What is the best Micro SD card if I would like to do 1080p video recording and loading the applications fast? I saw that SanDisk 64GB SDXC is a good one. But, I would like to check with the experienced people before buying the same. Anybody have a recommendation? I am fine to spend more money as long as that is worth. Please kindly advise.
Thanks a lot in advance everyone!
