Help me find a good PST backup tool standalone software
Hello!
Does anyone know a good PST backup tool standalone software? I am looking for a software that I can use in managing my personal folders and files. Any recommendation or suggestion?
Thanks!
Best Answer by Walton Stockstill
Answered By 85 points N/A #173148
Hello
Mailstore Server will work well for your purposes. It saves all the PST files in one location. So there is no need to have multiple PST files in multiple folders and servers. If you need to change computers or lose all your data, restoring files is really easy. There is a 30 day trial available for download.
A free alternative is Safe PST backup. Backups run automatically so no need to remember to back up your files. It will only backup the files when changes are made, so backups are done fast
Answered By 0 points N/A #173150
Backing up emails in ms outlook is never easy. You can always install standalone software but remember one thing as a rule of thumb, ms outlook never allows it PST file to be copied while you are working. I mean you deleted your data files accidentally and when you go back to software, you see copying errors.
My intention is to tell you that shadow copying must be used; otherwise copying software is good for nothing. I recommend you to use cobian backup utility. It has multiple choices and you can configure it easily. Top of all is that it is totally free.
