Help me to find image url code creator
Hello everyone,Â
I am working with some HTML code. I need an image url code creator for creating HTML pages. Can anyone help me how to find code creator on the net?Â
Thanks.Â
Hello everyone,Â
Thanks.Â
Hi John L Krug,
It is very easy to use an image to create a link.
You should just follow some steps after follow these steps I think you can do perfectly your work.
Find the code file attached:
Here I used pulpit.jpg you can use here any of your choice but mind it HTML file and your image must be staying in the same folder.
You should write the exact name of the image in your HTMLÂ code. For more help just go to this link
Good luck
Hello, John
Hope you are fine.
I understand your need. I can suggest you a name of website which provides the image code for your webpage.
There you will find a box where you will just put your image url.
However scrip generator also generates an image html link.
Text and Image HTML link Generator
Hope you will get your answer.
