Help me find Nokia X3-02 plugins for Mac OS
I kept on searching Nokia X3 02 plugins for Mac OS X 10.6.6 Snow Leopard but couldn’t find it. First of all I want to know, is there plugins for Mac Snow Leopard? Can anyone help me find. Share the name of store I can buy from or link if it can be downloaded.
Answered By 5 points N/A #152114
Hi Barb Brennan,
You are looking for Nokia X3 02 plug-in for Mac OS X 10.6.6 Snow Leopard. Yes, I got Nokia X3 02 plug-in for Mac OS.
iSync plug-in is used to synchronize your data using iSync-Apple's hot synchronization software built into every modern Mac computer.
You can download iSync plug-in for Nokia x3 from the mentioned link:
https://moviezdeservedcu.cf/x3-02-isync-plugin-dmg
I hope it will helpful. Thanks!
