Hello guys,
To day I came here for a suggestion. Now a days there are many soft that can fix our pc problems like registry error, software framework error. But I am not sure which software is more promising. So please suggest me a best pc error fixer software.
Help me finding best pc error fixer software
Hi there,
In my opinion, I would suggest you to reinstall your operating system, this is the only best and promising solution or you may try to recover your system using system restore.
Regarding software's I would suggest you to download Hirens Boot CD which has a program called Malware Bytes.It will erase all the viruses and infected files and so on.You can download it in the link below​, but you have to run it in safe more though http://www.afterdawn.com/software/system_tools/operating_systems/hirens_bootcd.cfm .It also has a lot more tools to offer like backup tools, CMOS tools, cleaners, device driver tools etc.
Hope this helped.
Hello John,
Welcome to the forum.
I will not miss the opportunity to help you with a great application to fix PC errors. In my last 12 years of IT experience I have come across so many software in the same category but there are two such software who are best.
1. CCleaner- Link for this : http://www.piriform.com/ccleaner
2.Tune Up Utilities – Link for this : https://www.avg.com/en-us/tuneup-utilities
Hope you will love these tools.
