Help me finding bis compatible streaming app
Hello guys,
I use a blackberry set for along time. You know there are many apps for blackberry out there. But all of them are not compatible with the old models. So if I want to test the compatibility of the app then I need Blackberry internet service which is best compatible streaming app.
Please help me finding this.
Best Answer by Horace H Henderson
Answered By 0 points N/A #167024
There is a good link from which streaming for all old and new apps which I recommend for all blackberry fans like I do.
My blackberry 8550 works fine on this 2 apps.
Make sure you have those USB cable ready and download.
I recommend using WiFi and works also with your favorite provider.
Answered By 0 points N/A #167025
There are no compatibility solutions for a Blackberry user, only on an enterprise level, to help those with older models migrate to newer ones. Because of the way apps work, they can only use the phone's own resources without connecting to the server and the very definition of streaming means that the app just delivers the content from a server. In other words, there are no ways to maintain compatibility of an older Blackberry model with a streaming app.
