Help me get into my Filezilla account.
I cant log into my Filezilla account . I cannot access this account because about 9 months ago I opened it .After long time when I want to open it ,so it can not open & didn’t work. Now I want to get back my account in filezilla.Please help me to find a solution. Thanks.
Best Answer by Babyface Nelson
Answered By 0 points N/A #127445
You haven’t used your filezilla account after nine months and now that you want to access it you can’t.
Here are the reasons why you can’t access your account:
  1. You have forgotten your username and/ or password.
  2. Your account has been deactivated after long periods of inactivity.
Here are the solutions to each reason.
  1. Request for your username and/ or password using the email address you used to sign up, Wait for the email and then access your account.
  2. The only to reactivate your account is for you to contact the admin and ask that he/she reactivate your account.
Answered By 10 points N/A #127447
Hello Ahany,
  • Are you pertaining to the FileZilla FTP??
  • If you are, then unlike what Zerolucky said above, that is not like an email account that you can request a new username and / or password.
  • The username and password to the FileZilla FTP is provided by your web host.
  • You have to log in to the web hosting account and get the details from there. Once you have gotten the username, password and all the other details needed for FTP connection, use FileZilla’s Site Manager to store those information in. This will be helpful for you in case you forget the username and password again. It also has more detailed information you can provide that “Quickconnect” doesn’t have.
  • If for some reason you cannot also log in to the web hosting account then that is where you may request your username and / or password if they have that option. If not, then you may have to call the customer service of the web hosting company to get those details.
If you are pertaining to the FileZilla forums at https://forum.filezilla-project.org/, then just follow what Zerolucky said. Or;
  • Go to the FileZilla forum log in page or click the link above.
  • Click Login
  • Click “I forgot my password”
  • Enter your Username and Email address
  • And look for the email from FileZilla.
If you’ve forgotten your username also, try to look for the e-mail that FileZilla forums sent to you when you registered the first time. Check your username and password in that email and try to log in again. It’s possible that an administrator of the FileZilla forum board has deactivated or deleted your account. In addition, may forum boards remove users who have not posted for a long time as maintenance and to lessen the size of the database. If this is what has happened, just register again and try to be more active in the discussions.
Answered By 10 points N/A #195651
Hello Ahany,
Though you aren’t used your filezilla for the long period that is why you can’t you access it.
It can be occurred for two reasons
One is you may forgotten your username and/ or password.
Two your account has been deactivated after long periods unused.
Here the solutions for two reasons.
If one is occurred just simply send request for your username and/ or password on your email
If they deactivate your account just active it
Thanks and Regards
Manik
