I have Windows 7 and I would like to use kingston usb software for making the organization of my data such as files and photo. However my friend has said me that it supports only Windows 8. Is it true and there is no kingston usb software for my version of Windows? If it is available anyhow and you know any of them please name them. Thanks!
Help me with kingston USB software please!
Hello there Anthony,
All operating system now a days supports USB connection in a fast way. And as to answer your question, do not believe what your friend has said because any USB can be read by operating system unless if it is damaged or not functioning right anymore. So please try first your USB before believing your friend there is nothing harm if you try.
Hope this helps you.
Regards, Roland.
Greetings Anthony M Guy,
You are looking for software which you can organize your files and photos on your Kingston USB. Purchasing a Kingston USB has its own drivers inside the USB.
When you open your Kingston USB you will see "urDrive.exe", that software is exclusive for Kingston USB. About the OS issue, Kingston USB supports almost all Windows OS from XP to Windows 8. For more information for your Drive please visit.
Jose D Dunn
