Help me with Lotus Please !!!
Hi Team ,
Could please help me regarding with the Lotus notes functionality in saving a file in a folder? As far as I know with other applications like in Blackberry it always suggest a folder destination where you can save your file. so can anyone tell me about that issue .
Thanks
Answered By 0 points N/A #100880
Hi
Notes folder or file is depends on the brand mobile configuration only. It means Black Berry's application will safe, descriptive, and easy. Your question is that saving file or folder of Lotus notes.
Follow then: Look Menu>>Applications or find Organizer where you should move the notes. go notes and add note.
You may find 1.subject  2. title 3. priority 4. sound  5. gifts etc.
Add as your demand and importance. so you can save easily in there. The file must save in the phone memory but move and copy system can save on the Memory card.
Your file destinations have two system phone and memory card. Hope you solve it.
