Help me make aigo mid install xp.
Could you guys help me to load my Aigo mid to windows XP? I have tried several procedures to make aigo mid install xp but I failed. I tried booting the aigo mid from my USB but it is not working.
Hello.
It is easy to mount windows xp to Aigo mid by using usb flash drive.
There are several video tutorials and forums that can help you solve your problem.
After a good research I found a forums website where you can get information about the windows xp to aigo mid installation.
Click on the below link to go to the website.
http://forum.ultrabooknews.com/archive/index.php/t-34526.html?s=57c97f50b099ca4176cedd2d10d2bcaf
Thank you.
Hello Araceliariana,
As you have mentioned you have failed to install Aigo mid windows XP.
Let me tell you it’s an easy process of installation you just have to follow the steps. You can do it with USB drivers.
You can check on a few sites to get the exact way to load it. Pocketables, ultrabooknews, umpcportal are the good sites.
Hope this will help you to resolve your problem.
Good luck.
Notifications
