Help me to Read this Please
Hi Team ,
I have try to use my HP G85 officejet all in one printer but pc doesn’t read it and I am not getting the original disk. Anyone can help to find problem? Thanks in advance
Hi Team ,
Hallo,
Looks like you are facing problem with your driver CD or I can say software. Yes it is only software what you need to run your printer. But the problem is you haven’t mentioned about your operating system. It would be easy for me to find the exact solution for you. But still I am giving you a link where you would find your desire software. And it’s totally free. Visit this link.
Click on this link and choose you operating system then you will redirect to another page. You will find download Icon on the below part of the page. Just click on the Icon and download the software.
If you don’t have the installation CD for your HP printer, you don’t need to worry because you can easily and readily download it from the HP website. To download the latest driver for your printer, go to HP Officejet g85 All-in-One Printer. Here, you need to select your correct operating system.
For Microsoft Windows, the driver supports Windows 2000, Windows XP (32-bit only), Windows 7, Windows 8.x, and Windows 10 both 32-bit and 64-bit. For the Macintosh computer, it supports Mac OS 9, OS X 10.2 Jaguar, 10.3 Panther, and 10.4 Tiger. Linux is also supported. Once the operating system is selected, click “Change” to go directly to your download. Just download the driver after this.
When installing the driver, first, make sure the printer is connected to your USB port using the USB cable or through the printer port or LPT port. Once the printer is connected, turn it on and double-click the downloaded driver to begin installing.
