Help me reducing the cpu temperature linux cinnamon
My Linux CPU Temperature is very hot, I need an overheated solution. Since its Linux, is there a way to reduce CPU temperature Linux cinnamon ?
There are different ways of reducing the heat that is generated by your computer’s CPU. The part of the CPU where the heat is actually generated is the processor. Right after turning on the power of the CPU, the processor immediately starts generating heat. This is then controlled by the heat sink which is attached on top of it. The heat sink directly absorbs all the heat generated by the processor and without it your CPU will suddenly shutdown because of overheating. This is used to level the generated heat.
To further lessen the temperature that is circling around the heat sink, a cooling fan is also attached on top of it. This helps lessen the temperature. The speed of the cooling fan is controlled by the CPU and as soon as the temperature turns hotter, the cooling fan automatically increases its speed.
