Help me with regedit clavier.
Hallow Users,
I am a keen PC user. I like to make fun by making changed the outlook of the windows. So I frequently change the keys in the regedit clavier editor but I don't know what I did last time.
Now I can not use my keyboard now.
I have to write using my mouse using the on screen keyboard.
So guys help me out from this situation.
Answered By 10 points N/A #166692
Probably you would have changed the registry settings related to input devices. Try re installing the driver software for your keyboard and try again. If this works you are lucky. Else, you should reinstall the OS.
As a precaution next time before you attempt to modify the registry take a backup of it.
This will avoid issue like what you are facing now.
