Help me to synchronize MySQL Linux and Windows XP
Hello friends, Please help me to synchronize MySQL Linux and Windows XP.
I would like to use the same database in both Operating System.
Hello Timothy
I will assume that you are using Debian-like distribution since those distributions are most used on desktops computers.
Open Terminal and type: sudo apt-get install mysql-workbench
After the installation is done open MySQL WorkBench and connect to your database.
Now you can manipulate with your database both from XP and Linux.
Cheers.
Hi Timothy,
You can follow the below steps to replicate the MYSQL LINUX on window xp as well.
1. Configuring Master Server
First edit /etc/mysql/my.cnf. Then enable networking for MySQL, and it should respond to all IP addresses, hence we need to comment out these lines.
#skip-networking
#bind-address = 127.0.0.1
Put the following lines into/etc/mysql/my.cnf:
server-id = 1
log_bin = /var/log/mysql/mysql-bin.log
binlog_do_db = exampledb
Then we restart MySQL:
/etc/init.d/mysql restart
Next, log into the MySQL database as root and create a user with replication rights:
mysql -u root -p
Enter password:
Currently we are on the MySQL shell.
mysql>GRANT REPLICATION SLAVE ON *.* TO ’slave_user’@’%’ IDENTIFIED BY ‘<some_password>’; (Replace<some_password> with a real password!)
mysql>FLUSH PRIVILEGES;
Then (Being On the MySQL shell) do this:
mysql>USE exampledb;
mysql>FLUSH TABLES WITH READ LOCK;
mysql>SHOW MASTER STATUS;
The last command should be like this:
| File | Position | Binlog_do_db | Binlog_ignore_db |
| mysql-bin.006 | 183 | exampledb | |
1 row in set (0.00 sec)
Save this information, as we will need it later on the other OS!
Now leave the MySQL shell:
mysql>quit;
2. Configuring Slave Server(Windows XP)
Edit c:program filesmysqlmysql server 5.0my.ini
server-id=2
master-host=db01.yourdomain.net (or IP address)
master-port=3306
master-user=slave_user
master-password=password
3. Restarting Mysql Service
goto> Control Panel>Administrative Tools>Services>Mysql
Restart the Service
mysql > Stop slave;
mysql>CHANGE MASTER TO MASTER_HOST=’192.168.10.175′, MASTER_USER=’slave_user’, MASTER_PASSWORD=’password’,MASTER_LOG_FILE=’mysql-bin.000008′,MASTER_LOG_POS=98;
mysql > Start slave;
hope this helps.
Thanks Baker
