Help Me To Fix Microsoft Security Essential For Window 7 64 Bit Home Basic. Please!
I am a Windows user. How can I download Microsoft security essential for Windows 7 64 bit home basic? What are the different ways to download?
Microsoft security essentials are the Antivirus which help your device to virus or malware free or to remove the harmful Trojan.
You can download it from Microsoft official website. Go to the link www.microsoft.com
Search for the software you need then open the application you need to download it on your PC, give the path where you want to store it on your system then after installing it, open the application.
You can also get it from Softonic or FileHippo.com
Make sure that the version you have downloaded from the site is suitable for your computer features, like you have a 64-bit system then download the 64-bit software only for better performance.
