Help Me To Resolve Error Code 1275
Hello, when I am trying to update BIOS on my computer then error code 1275 is showing on my system. What can I do to remove this issue?
If you are getting this type of bugs then firstly check that in what privilege you are having you are a local user or have administrator permission because that is important. Now go to Start Menu -> Control Panel then go to advanced system setting then select the setting of performance in advance system after that turn on DEP which is Data Execution Prevention option, then add the Winplash.exe file to it, apply the changes and now try to execute the file again it will help you to remove your fault.
That error may be specific to the brand of your computer. If you can’t update the BIOS and keep receiving that error, check with your motherboard’s manual for the correct procedure on updating the BIOS. If your computer is branded like you are using Dell, HP, Lenovo, Acer, and others, download the latest BIOS update from these manufacturer’s websites:
Updating the BIOS is for adding features and functionalities only if this applies. You don’t need to update if everything is working fine.
