Jamin Ywain
60 points
Posted on - 09/22/2012
I am downloading this application on my computer when the progress bar started to hang during the 32 % download process. I tried to download the exe file again, this time, it stops during the 56 % download. I temporarily disabled Firewall settings and antivirus as this may the cause of the issue, but still, my download progress hangs at particular download point. So, I suspect flash player software installer is causing the issue as I read that it has trouble working on some firewall proxy server environments. Can you please provide any possible workaround to resolve this download issue I am experiencing?
Help me with Trouble with flashplayersoftware installer
Good Day,
What browser are you using? (e.g Internet Explorer, Google Chrome or Firefox)
If you are using Internet Explorer and failed downloading Flash Player, try using other browsers
Where are you downloading your flash player?
Download Flash Player on https://get.adobe.com/flashplayer/
Did you check your internet connection if it is intermittent or not?
I think the problem occurs randomly because of your internet connection. Try to check your internet connection if it is intermittent or not.
You can always identify if the version of adobe on your computer, is compatible with the Operating system running your computer. Most of the flash players will download and install simultaneously. Whenever the network is at low speed this would result in an installation failure as the installer will try to extract files that are not fully downloaded try to enhance your network connection. This link will give more guidance: helpx.adobe.com/flash-player/kb/find-version-flash-player.htm
