Help me on unlocking the zte kis?
Hi Experts,
I am having a ZTE router that need unlocking.If anyone know unlocking the zte kis.I tried to unlock using advanced settings reset button.But it was unsuccessful.Any experts help me on this.Thanks.
Dixon Eartha
Best Answer by Hathy greave
Answered By 0 points N/A #133573
You need to unlock your ZTE router. One thing you need to know that it was furnished for the respective SIM card while it was programmed by the concerned service provider for their business purpose. The reason is that you should not access any other network on your phone other than the service provided by the company.
But there is an easy way to unlock it. For this you are suggested to insert IMEI/serial number of your phone. Your will get your phone unlocked. Now you will get network access on your phone to any other SIM card from any company.
I hope you understand it.
Answered By 0 points N/A #133574
Hi Dixon,
I tried for long to solve your problem and at last got a solution. But it is so easy that after getting the solution, I just……
Anyway, I have got a solution it is important.
To get rid of the problem, just go into network setting and add your new network APN setting and then use.
Is everything clear?
I think yes.
Thanks for asking.
Hathy
