ndy_ad
200 points
Posted on - 06/20/2011
Is there a software for a mobile phone to divert calls?
I often receive crank calls, and I’m getting tired of having it.
I wish to have this application for my phone to eliminate this unwanted calls.
corlis
Software that can divert all calls on mobile phones
Hi
I can understand the problem. And I think as the cell phone are going to be a part of our daily routine, this problem automatically has been adding into our life and makes very tough times for us sometimes. For the solution of this problem many of the applications are available in the market and some of them are built in with our cell phones. If you identified the model and company of your cell phone then it will be easy for me to help out. Anyhow some of the settings I can give you here, if you found one of them in your cell phone then it will help you to fix it with.
Firstly, check for the “Call Diversion” method:
GO to Main Menu of your cell phone.
Select “Settings”.
Search “Connectivity” mode or tab from your list of settings.
Now, in this new list you can find out “Call Divert”.
There is a list of calls you want to divert, voice calls, unknown calls, etc.
Select the required calls details for diversion.
Secondly, check for the “Manage Calls” method:
Select “Settings”.
Now, in this new list you can find out “Manage Calls”.
There is a list of calls you want to manage like calls waiting, Accept calls, Restrict Calls, closed groups, etc.
I am using “Accept Calls” settings to ignore all unknown calls. Before this, you need to make one or more groups of your required numbers; from you want to accept calls. Add those groups into your accept call’s list. And that’s it.
Now you don’t need to worry about unwanted calls, because every time any number except your accept call’s list, will dial your number he will find your number busy, and you will just receive notification only.
By using this method, you don’t need to install extra software or don’t need to pay money for that. Enjoy
In mobile phone technology, call divert is a phone feature that enables the user to forward or redirect their incoming calls to an alternate number, which can be a landline or cellular number. Users can also choose to divert incoming calls directly to voicemail. When call divert is enabled, the phone does not ring at the original number of the incoming call, but rather only at the locations the call had been diverted to.
With that, there is a LANDIAL that will help you solve your problem. This program can be set to call divert number before dialing DUN and call a cancel number after so it works in UK etc. Also allows control of DUN dial / hangup over LAN with companion program LanMsg. What's New: fixed win2k bug, delays at least 1 period
To download, select LANDIAL here’s the link – Download Mobile Phone Call Divert Software
