maciej
Posted on - 11/03/2011
Hello!
Please help me to upgrade my computer.
I have AMD Sempron with 512 MB memory. 40 gigabyte hard disk.
I want my computer to be fast in either browsing or in gaming.
I don’t know which area I have to upgrade.Â
Please guide me.
Thank you.
Help me upgrade my computer
Hi Maciej,
For a better and speedy computer we have to upgrade in the PCs RAM. Â
But then before adding a RAM, you should know first how much memory is needed for your computer. Â
It all depends o the capacity of your computer to handle a much larger memory RAM.
   What to do if my computer needs more RAM?
On your Windows Task Manager open it to check your free space memory.( RAM)
Then you have to click the PERFORMANCE TAB and it will notify you if there's still available space memory. Â If it indicates "0" that means you have to add your RAM memory.
Hope this might help you.
Thanks
Hallo Marcie,
The areas that you have to upgrade in the computer include the RAM and the hard disk space.
Since you aspire to be a gamer, then you need to upgrade your computer to a super fast speed.
The best specs for a computer for gaming are as follows:
Hard disk space of not less than 320 GB to store the gaming programs.
A RAM memory of not less than GB to improve the speed at which the computer processes.
A processor speed of above 2GHz.
Since your computer has only a memory of 512 MB and hard disk space of 40 GB, you will need to tremendously upgrade so that the computer may be good at gaming and browsing.
Regards
Mahesh Babu
