Help me with this USB flash drive
Hi experts ,
Anybody can provide me an USB flash drive +16GB with CDFS partition please? I have need that drive as encrypted but encrypted software will not contain in CDFS partition.
Thanks in advance.
Hi experts ,
Thanks in advance.
So I am showing you the way in the picture below:
It’s not easy to find a flash drive with partition option, because you can’t make partition to a removable disk. But I find a solution for your problem that you have to work it as hard drive. To that you need software called Lexar USB format tool.
But this tool is not computable with all USB flash drive so you need to buy a Lexar Flash drive. I am giving you a model number Lexar Jump drive v 10.It is the best among all other Lexar drive.
But still you need to make it work like hard disk to create partition.Â
