Help me with vbs pop up volume.
I need some one to help me out with VBS pop up volume. I want to create a pop up message after registration and login but unable to do so since I have not good knowledge on VBS pop up volume.
Follow  this instruction:
     1. Open notepad
2. Type in the following …..
o   answer=msgbox ("Fill in your title", enter 8, 16, 32 or 64 depending type of box (error, information, etc.),"Enter your message")
3. Save as…
4. In whatever file saves as whatever you want ex: internet. VBS MAKE SURE YOU NAME IT AS .VBS
5. Create a shortcut of the file ON YOUR DESKTOP
6. Right click
7. Properties..
8. Change icon…
9. Choose whatever icon you want … In my example I use the internet explorer icon
    10.Delete your REAL internet explorer temporary (doesn't empty recycle bin) and..
To know more about How to make a popup message using '.vbs' – watch this YouTube video
Hope you will enjoy it.
Thanking you
Franke Mary
