Help me When I run the program Netframework Unhandled exception
hi netframework error occurred
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue.
This message appears as attached
Smtp error similar programs or
Server connection error occurs
When I run the application exe
Net framework 4.0 standalone install
That's too hard.
Please describe in detail
See the end of this message for details on invoking
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
