joan d vogt
10 points
Posted on - 09/22/2012
This website has helped me a lot with my previous computer problems and I want to come back with another situation that needs an SOS. I am no computer expert, so I will just rely on help from you guys.
Ok, first and foremost, my PC is running a Windows XP 32-bit Service Pack 3. The problem is in the message notification mass effect. What happened is, when I click the play button on my Mass Effect CD menu, then a message notification with an error appears. When I installed the game, I haven’t encountered this problem.
Help with message notification mass effect
Hi Joan,
Glad you are finding the site useful. We are always here to help you in anyway you can. Now in order to help remedy your errors, we need to know what exactly is the error before we are able to provide a solution.
Hello Joan,
The most possible reason for getting that error report is, not fulfilling the requirements that are needed to be fulfilled by your computer in order to play that game. So first check whether all the requirements are fulfilled by your computer. Sometimes this happens when the exe file is corrupted or some of the essential files are missing in the installed game. So try to reinstall the game and if it doesn’t work make sure that you bought an original DVD. If it’s an original you must complain about this to the game company. If it’s not an original you just have to buy a new original one.
