John B Loar
20 points
Posted on - 04/02/2016
Hi everyone,
I got an error message during installation of Microsoft Office 2016 in my Windows 10 Operating System. I downloaded a compatible version of Office but there is an issue appeared. Can I fix this issue? Your cooperation would be appreciated.
Office
We found a problem!
This installation requires a compatible Microsoft Office program installed on your computer.
Help Microsoft Office Installation Error
That error normally appears when installing Office 2016 ProPlus. The error is thrown because the line that contains <Language ID> was removed and the configuration.xml looks something like this:
<Add SourcePath=”c:office365″ OfficeClientEdition=”64″ >
<Product ID=”O365ProPlusRetail”>
</Product>
Adding the line for <Language ID> should fix the problem. If you want to edit your configuration.xml file, make sure it contains the following or else you will run into problems:
<Configuration>
<Add SourcePath=”c:office365” OfficeClientEdition=“64” >
<Language ID=”en-us” />
</Product>
<Product ID=”VisioProRetail”>
</Product>
</Add>
<Updates Enabled=”TRUE” UpdatePath=”\ServerShareOffice” />
<Display Level=”None” AcceptEULA=”TRUE” />
<Logging Name=”OfficeSetup.txt” Path=”%temp%” />
<Property Name=”AUTOACTIVATE” Value=”1″ />
</Configuration>
After this, you should be able to successfully install Office 2016 ProPlus.
