Help Microsoft Visio Standard is not working
Hi everyone,
I have installed Microsoft Office 2016 in my Windows 10 Operating System and trying to use Microsoft Visio Standard using this program but an error occurred during this process. How can I fix this problem? I need experts’ suggestions to get rid of this problem.
Office
Stop, you should wait to install Office 2016
We ‘ll have to remove the following if you continue:
Microsoft Visio Standard 2013 – en-us
This app doesn’t work with Office 2016 right now. We’re working on a solution.
Answered By 590495 points N/A #185136
If you currently have Microsoft Visio Standard 2013 and an error was thrown when installing Microsoft Office 2016, it means you will not be able to install Microsoft Office 2016 if Microsoft Visio 2013 is around. You need to uninstall Microsoft Visio 2013 before you can install Microsoft Office 2016. Microsoft Visio 2013 is not compatible with Microsoft Office 2016. So, on that dialog box, click “I’ll wait”.
After that, uninstall Microsoft Visio 2013. Click Start, Control Panel, and then “Add or Remove Programs”. Scroll down on the list and select Microsoft Visio 2013. Click Uninstall or Remove and wait until it is finished. If a system restart is required, restart your computer. Next, install Microsoft Office 2016. That should do it. If you still require Microsoft Visio, you need to install the latest.
Go to Microsoft Visio Professional 2016 to download. But before you can download, you need to log in using a Microsoft account to be able to download Microsoft Visio 2016. If you don’t have one, create a new Microsoft account.
