Help my MacBook Pro won’t load
Why is my MacBook Pro not loading? I have recently forced quit an unresponsive app on my MacBook Pro laptop and the system shut down abruptly. I later power on the laptop, but the system would on but taking a long time loading. What should I do to make the system work again?
Answered By 0 points N/A #189759
It is possible that the unresponsive app made your MacBook Pro to malfunction. A great way to solve this problem is to boot on Safe Mode. To boot on Safe Mode shut down your Mac, then start you MacBook Pro and quickly press and hold the Shift key during start up. Once on Safe boot and your MacBook Pro functions properly then try to find that unresponsive ad and try to remove or uninstall it.
