hpc024
Posted on - 10/08/2011
I got this problem with my opera browser. It's html codes seems not working very well. Every time I open my browser I see some lines on the screen. I can't even use the scroll.
I have uninstalled it and installed it again but the problem remains the same, I don't know if the problem is with the browser or it's with my system.Â
I really need your help.Â
Thank you in advance.
Help with my opera browser
If you have already uninstalled it and installed it back and still nothing happened, maybe there is something wrong with your operating system. Run a disk check on your hard drive so you can check if there is an error in its file system. If you are not familiar in doing a disk check.
Here is how:
Right-click on drive C and then choose Properties.
Click Tools tab.
Click Check Now button.
Check Automatically fix file system errors and then click Start.
If you are using a quite older version of Adobe Flash Player, update it to version 11.0.1.152 which is the latest release and can be downloaded at https://get.adobe.com/flashplayer/?promoid=BUIGP.
The same with your Opera browser if you are not using the latest version download it now.
The latest is version 11.51 and can be downloaded at http://www.opera.com/.
