Help Needed for CSS scripting
I created a CSS script but how ever need to add a padding around the text such that the width changes on Mouse Over event.
i have created the JavaScript however am unsuccessful in creating the CSS file.
I have attached the script below.
Any help from your side would be appreciated..
Best Answer by Harpe byers
Answered By 0 points N/A #88517
In Cascading Style Sheet (CSS) a:hover is used to give the text decoration required when mouse comes over.
a:hover can contain many text decorations.
Example:
  1. <style>
    a:hover { color: #000; text-decoration: underline;}
    </style>
  2. <style>
    a:hover { color: #000; text-decoration: underline; font-family: Arial, Helvetica, sans-serif; font-size: 10px }
    </style>
  3. <style>
    a:hover { color: #000; text-decoration: underline; font-family: Arial, Helvetica, sans-serif; font-size: 10px; background-color: #CCC }
    </style>
But this only works for the links. CSS don’t have such thing for normal text. You need to use javascript for this.
Thanks,
Anne
Answered By 10 points N/A #88519
Hi Myron,
You don’t need to install JavaScript.
Follow these steps –
1. Please open a text editor say Notepad.
2. Type (or simply copy paste) following code to create a blue square of 250 pixels
<html>
<body>
<style>
.block { display: block; height: 250px; width: 250px; background-color: blue; }
</style>
<div class="block">
</div>
</body>
</html>
3. Close and save the document at desktop with name that you like following .html extension.
4. Open the file from the desktop in a web browser (Simply drag and drop in a browser and you will see the blue square)
5. Open the Notepad again and enter the following source code right before – </style> tag.
.block:hover { height:400px; width: 400px; }
which is programmed to resize blue square to 400 pixels when the user hovers over the mouse.
Answered By 0 points N/A #88521
For adding a style and selecting a link when the mouse will get over it, you need  to add a simple CSS :hover selector.
Example:
a:hover
background-color:yellow;
If you try this code, you will see that the background color of your link will change to yellow.
For adding more effects you can use the :link, :visited, :hover, :active and other selectors.
Good luck codding,
Aabel
