I have a Cassiopeia handheld PC with windows Ce.I have a setup of sqlite in my flash disk. Can I install and configure sqlite application on windows Ce? Will there be any problem if I install it or is it better to use sqlite on desktop or a laptop even?
Please someone suggest me what to do with flash disk windows Ce sqlite?
Help needed for flash disk Windows ce SQLite?
Hello Benjamin,
Sqlite is an important software for the Windows SQL database.
Yes, you can install and configure the Sqlite application on Windows CE. It doesn’t matter if you are installing Sqlite on a desktop or a laptop. If your PC has the supported configuration, you may install it.
Your Cassiopeia handheld PC with Windows CE can run the Sqlite, but you may have some problems. Sometimes, your PC may be slower when you are running it, so I suggest you upgrade your PC configuration.
Hi there Benjamin,
SQLite is a small C library that implements out of the box working SQL database engine to your OS. It is designed to work on all platforms, including Windows, Linux and Windows CE, so you should have no problems running it.
It should run faster when installed on the Windows CE than on normal OS, so I would suggest you to go for it and install it on your Cassiopeia.
