Help needed on Microsoft Outlook 2010 subtasks
Is there a way to have or does anyone know how to set up microsoft outlook 2010 subtasks? Any kind of help is aprreciated. Thanks in advance.
Hi Karamel Roset,
As I have researched the Internet for possible solution, I discover that there is a way in creating subtask with your outlook 2010. I have attached a link below for more information
EHOW: Create task / Subtask on MS Outlook
Microsoft Office: Outline tasks into subtasks and summary tasks
Hope that would help you.
If you want to create a sub task in MS Outlook, it is very easy. To set up a sub task in Outlook, just follow these steps. Just use the shortcut "Ctrl+Shift+K" or click the Office Button, then New Appointment, then Task, then Create New Outlook Item, or click the drop-down arrow menu, the "New" button, and select the "Task," or "File" menu, point to "New" and then click "Task."
Notifications
