Help needed regarding invalid package
I have downloaded an entire folder of 500 MB of Sims 3 Packs.
It has an invalid package file, what do I do with it?
And also you can’t multi-select.
Must you do it 1 by 1 or is this an oversight?
Clean Up Sims3packs Today! Also raises dead? v1.0.3690.2514
Unhanded exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Not a valid package file.
