Help is needed with splitter stereo file software.
Hi experts,
I need some help with my stereo file splitter. I want to split a stereo file into two mono files with the stereo splitter. How can I split a stereo file using the splitter stereo file. Please show me the way.
Best Answer by Ware Shaul
Answered By 0 points N/A #170926
  • You can download Slice Audio File splitter from http://www.nch.com.au/splitter/index.html
  • Install the application, selecting all the installation options
  • Run the application
  • Click “Add Files” from the tabs
  • To the left of the window, select “slice into” and chose the number of files you want to slice the audio into.
  • Choose the location to store the split files
Alternatively, try downloading the following software
Digital Performer or AudioDesk.
Answered By 0 points N/A #170927
Hi Yelverton,
There is one leading splitter stereo file software in the market. It can split stereo files into two mono files. This is the Studio One Stereo Splitter File Software. Kindly click the link below to download and review the software.
Studio One Stereo Splitter File Software – This is a deep and easy to use and easy to learn software where you can integrate different plugins and perfect for sharing and collaboration.
Ware
