Help on picking out a Web-cam?
So my boyfriend is going to college next month and we're going to get web-cams so we can face chat since I will barely get to see him with his freshman year of college and my senior year and both of our sports but, Anyways.
I was wondering what type of webcam is the best.
I've heard some are extremely defective and I don't want to get a bad one. Help please?
Best Answer by Floss
Answered By 0 points N/A #88266
Hello there,
Basically all webcams are good for just a normal chit chat, but if you up to definition try getting a HD webcam BUT really its a waste of money, Because the more definition that you are using the bigger its file size thus making it hard for it to reach your boyfriend(but if you both have super fast internet speed then why not give it a shot).
IMHO just buy a normal webcam for about 20-30$ I have heard logitech and creative are good brands. Also there are webcams that have built in microphones i think its worth the package.
Goodluck !
Answered By 5 points N/A #88271
Dear Rasel,
Relatively all webcams are pretty good, they vary only in resolution and price. If you need a high resolution cam, you can try relatively high priced ones, like Creative, Microlab brands. And if you are looking for better quality and lower price, you can try Logitech and A4tech brands also. They come up with a bit lower price.
Following links may help you a little:
https://www.logitech.com/en-us/video/webcams
https://www.bestbuy.com/site/computer-accessories/webcams/abcat0515046.c?id=abcat0515046&intl=nosplash
Answered By 0 points N/A #88272
I would advise you to purchase Microsoft LifeCam VX-3000. It is a great web cam in the sense that it consist of low light setting which does not require any much light as far as your computer screen is bright. It also has a built in MIC.
It is also helpful in making videos. It shows you very clear pictures of the other end you just need to adjust the nozzle in order to get clear pictures. Structure wise it is nice and small and could be adjusted anywhere.
The web-cam also have great variety if settings and options so that you could use it as you wish and as you like.
Answered By 5 points N/A #88273
Well, I am fixing to get one for a notebook computer.
The one that I am going to look for is the:
Logitech Quickcam Pro for Notebooks
If I needed one for the desktop, I would get the:
Logitech Quickcam Pro 9000
You can also do a search on these to read some reviews.
I would probably shop Amazon for a good price.
Source(s): https://www.trustedreviews.com/reviews/logitech-quickcam-pro-9000
I hope it will work. 🙂
Answered By 5 points N/A #88269
You really need a web cam which a high resolution, because a web cam with low resolution cause the grainier in the picture and its view. You need to fix the resolution which is recommended and it is 640 x 480. Also make sure that your web cam is of high frame otherwise the image of web cam will be blurring or stutter and cause the freezing of picture for a while. Let me tell you that the frame rate is always measured in frame/sec. so you must see the label of fps on the web cam. Now auto lights and focus are also available in new web cams. You can adjust every thing as you like to do. So it can perform better and good.
Hope that will be enough for you web cam.
Have a good day!!
