Help, Please, Immediate Help Needed For ost Conversion To pst.
I have run into a problem while using Exchange. I deleted an email on Outlook by mistake. Afterward, I saw that it was an ost file. The password has been changed. Can someone tell me how ost conversion to pst is done, as I do not know the new password?
Answered By 0 points N/A #194543
You can convert OST to PST by using the following method.
• Open Microsoft Outlook 2010.
• Go to File.
• Click on the Import & Export option.
• The Import & Export Wizard will open.
• Click on Export to a File.
• Click Outlook data file or PST.
• Select the Include Subfolders option.
• Click Finish.
a) If an existing file that is protected by a password is exported, enter the password in the Outlook data file password dialog box.
• Click OK.
b) If the PST file is to be given a password, type it in the dialog box Create Outlook data file.
• Click OK.
• Type the password in the Outlook data file password dialog box that will appear.
• Click OK.
