BoyerRandy
Posted on - 12/07/2011
Dears,
There is a little red ball badge in the firmware of Apple V. 5.0.1 since the release of the update. I am aware that it is showing because, I did not update the application and I don’t want to update the same.
I am looking for help to remove the red badge without updating the application. Please help me get rid of this.
Randy
Help remove settings of App Badge in iPhone V 4
Yes, since the release of apple 5.0.1, everyone is having this red-badge problem on iPhone. Â It is truly annoying. There is simple but very effective solution available on the net. A jailbreak tweak called noOTA badge can help you remove this red badges. You can download the noOTA absolutely free from the net.
From your iPhone browse the noOTA badge and download it. Then install the program. Keep in mind that, it will not install any new icons, and no option is accessible for settings change. You are now free from iPhone settings notification red-badge, and you will not be annoyed anymore by the red-badge icon anymore.
RegardsÂ
Crawly Math
