Help to repair damaged Photoshop data
I have a photo studio. Today I found that some old pictures in my computer are unable to open and require repair. Which option can help me to repair damaged photoshop data to recover my pictures?
Hello Acke,
A software called Recovery for Photoshop will help you repair the corrupted Photoshop drawings in the following formats: .pdd, .psd.
The data that is recovered is saved into a set of bitmap files (.bmp), with each of it representing one layer of the original Photoshop file or as a file in original PSD format at user's option.
Carl
Hi Acke,
Photo Shop Repair Toolbox is software used to recover .psd files. You need windows 2008 or above to download this. You can be easily restoring files with this tool. You can also preview the details. It can be used to repair corrupted file also. You can buy it for 27 dollars. It adds your photo to the new psd file automatically. This is doing as a step by step process. You can download it from http://www.photoshop.repairtoolboxx.com/.
Thanks!
I also use Adobe Photoshop, and if Photoshop files are old, they tend to become corrupted. So I, too, needed recovery software. Both experts have given me an answer but I like to use Head Jonathon’s software, it’s great. All types of Photoshop files can be repaired easily within a second! I found many of my favorite projects that were corrupted to be converted very easily. A lot of thanks goes to Head Jonathon and Superb!
Notifications
