Help required to insert new line input in Excel 2010 using formula
10 points
Posted on - 05/23/2015
I appreciate your time in helping me in inserting a newline character in the formula. Is it possible to display the result in two lines? The two lines will be the output of single formula in Excel. How to insert the line break in the formula? Does any formula exist for the requirement? If it is possible to insert new line character in between the two lines what is the way to do? Should I do some formatting of entire page before running the code? The two lines should be in the same cell but in two different lines like as in we do manually by typing ALT Enter
