Help required : For uninstallation of Snow transformation pack
Hello! I am currently running Windows 7 machine and I wanted to make it look like a Mac. The problem is that I cannot undo the changes. I managed to remove the Snow Transformation Pack (STP) though the computer still shows the Mac OSX background. In fact, the login screen and even the appearance of the computer still look like a Mac, including the icons. I was not able to create a restore point and now I cannot risk an uncertain restoration or reformatting. I hope somebody can explain how I could figure this out. Thank you in advance.
Answered By 0 points N/A #109790
It was Mac but currently your desire to run with Windows 7.But you have faced some problems that you couldn't solve it yourself.You couldn't undo or redo the intention to do changes.You couldn't delete the Mac OSX scene aspect.Besides commensurate icons and the login screen with also the appearance of software still alike the Mac.In this period you would required to uninstall the Mac OS.Don't worry you would necessity to knock on the program chapter for uninstall update of your Mac.Read the uninstall list.Search the name of Mac in that list.When you click on uninstall it will uninstall.You can run smoothly with your Windows 7.
