I am trying to pull up new vehicle inventory for a Ford dealer. I am using Safari and I get an error message here.
Error 500: Handler processing failed; nested exception is
java.lang.OutOfMemoryError
Please can anyone tell me what this is?
HELP to resolve Error 500 in Safari
The error message may be similar to an HTTP error. This error may be produced by the web server where the site is associated with and not caused by your Safari browser.
This may also be brought by an error with the page itself that you are trying to load or access. The java scripting or coding might not be filtered properly.
To troubleshoot further, try using a different browser to access the page. If same result happens, then for sure, it is not a problem with your computer. You can also reboot your computer to refresh any connection between your computer and the server where your browser is trying to connect.
