Help resolve problem with cpu network meter gadget?
Recently I added cpu network meter gadget and facing problem. Problem is, there is no data to show, just white box. Does anybody know the cause of this problem and how to rectify this issue?
Hello Emsey,
If you are using the latest network meter, at the top of it you should see 2 options which are as follows:
You will need to choose which of the 2 connections you wish to use, as well as the network interface of your router for the internal IP as well the speed. After you have done that you should be able to see the traffic.
Also make sure that you have an active connection to the internet for you may be currently working offline and as a result getting the issue.
Hope that helps.
Carl
If you’ve installed the “All CPU Meter” gadget but there’s nothing shown on your screen, make sure the program is compatible with your computer. If you haven’t updated yet to the latest version, download the latest from All CPU Meter. It supports Windows Vista, Windows 7, and Windows 8 including Windows Server 2008 and Windows Server 2012. If it doesn’t work after installation, try restarting your computer.
One user also encountered the same problem after installing the program. Restarting the computer fixed the problem. If this didn’t fix the problem, one possible reason is an unsupported processor which can happen on old single core processors. “All CPU Meter” shows your CPU usage (supports up to two processors, 16 cores, and 32 threads), RAM usage, CPU frequency, and processor name whether Intel or AMD.
