Help ROBOTC: License Activation Error
Hi experts,
I was using ROBOTC properly with valid actvated status but why I got this error message “Activation Error Code – 9105 (0)(0)”. Can you please send me proper instructions to fix the error? I would be thankful to you. Thanks!
Answered By 590495 points N/A #184724
Unfortunately, that error code is not included in their list of error codes for ROBOTC. The nearest possible code for it is 5022 but still, it is a different issue. Error 5022 is for Invalid System Time which is entirely different in your case. I also found the error 9105 (0)(0) on their forum website but the issue seems to be unresolved.
Since it is an issue related to product activation, make sure your computer is connected to the internet when activating ROBOTC because the license requires online activation. Also, check the requirements for ROBOTC to check if your computer meets the necessary requirements. If the problem persists, you may need to contact ROBOTC at support@robotc.net and describe your problem.
