Help for Samsung Wave 4 unlock themes
Hello guys! I actually want to change my themes for my Samsung. I need your help for Samsung Wave 4 unlock themes so I can change the appearance of my phone. Thanks!
Hi Jose,
I would ask you to try and do the following steps in order to set your desired theme.
1 Press the Menu Button.
2 Then touch My Files
3 Then touch images.
4 Then touch the required image / Theme.
5 Next touch options.
6 Next touch set as
7 Next touch wallpaper / Theme.
8 Then pinch and zoom to the required size.
9 Then touch set.
10 Then wallpaper / Theme has been set.
Kindly try and hope this helps you.
Thanks
Baker
Notifications
